what have i got here.. vin decode help
speedmachine
Ontario Canada
1GCGD34J9HF39992 OWNERSHIP SAYS ITS a 1987 CHEV D30 it does not have its data plates nor do i have any history. truck had flat brackets in the cab on the pass floor and tunnel, as well as a tube the went through the floor for wiring i assume. any further info greatly apprecited Lee
Skinny
488
Portsmouth, NH
I'm uncertain what you are looking for? Are you unsure if it's a CUCV or a specific model?
If you are trying to buy parts it is pretty much an 84' K30 diesel except for the starting and charging sustem.
CARNAC
The Envelope Please.
651
Corpus Christi, TX
Validate the VIN yourself. I don't think #'s HF #'s is military. Could be wrong, it might be USAF or USN. If it is FF then it is Army and I have a record for it.
This is why I say to validate the frame numbers.
Skinny
488
Portsmouth, NH
Yup...looks like another CUCV
Who cares what it is, RUN IT!
Post up a photo of the interior dash and under the hood so we can see if it looks stock or cannibalized.
1,808
I think someone stole a character from your VIN. I would be interested in seeing the VIN tag up on the dash behind the windshield. It would be tough to title here with a missing character. All the numbers in the VIN check out to be a 1987 M1008. There is certainly a character missing from the production sequence number. Have you checked the VIN tag up under the glass?
11Echo
92
CT W. R.
G indicates 8001-9000 gvw.
H is 1987 model year.
F indicates built in Flint.
Warthog
232
OKC, OK
If it was built in Flint, MI I would assume it would be a 17 digit VIN. Wonder if it was exported directly to Canada.
Warthog
232
OKC, OK
Seventeen digits. You left out one of the nines in the first post.
1GCGD34J9HF399992
1987 M1008
As stated earlier, CARNAC may be able to find some info if it was US Army.
Pull up the 2013 VIN Info thread. Be sure to read and follow the instructions in the first thread
markg
hutto,tx
shaft wasnt bent, door dent was a previous owner addition. would love to have more infor ation about where it served. not sure if theres anyway to find that out.
87 was the last yr for the cucv I truck. the first truck in that yr would have hf300000 built around 8-86. of all the 87's ive heard about in the us ive never seen a sequencial number over 320000 with a build date of 9-86. i think this was an export truck built later in the model yr. what does the data plate say about production date? thanks, mark
Warthog
232
OKC, OK
I looked up the truck at www.compnine.com. It does show that it is a military truck. (one of the few that does show up). Sadly it doesn't show the build date.
I'll pull the report again and send it to you.
The Compnine site lists all the RPO codes for vehicles. I use it quite often so I bought a membership.
Warthog
232
OKC, OK
Report for..
1GCGD34J9HF399992
Vehicle:
Not Listed
Year:
1987
Build Date:
RPO Description
76I INTERIOR COLOR,BRONZE (76I)
76V Unk.
A52 SEAT,FRONT BENCH,3-PASSENGER FRT BENCH ST(A52)
CMD Unk.
C6V Unk.
D1U Unk.
E5Z ADAPTER - SPEEDO - DELETE
E6C COUNTRY - GAMBIA
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
E9Z KEY - SPEEDO - DELETE
GAM VEHICLE - GOVERNMENT (G.S.A. SALES)
GQ1 AXLE,REAR,STANDARD RATIO(MERCHANDISING OPTION) STANDARD RATIO R/AXL(GQ1)
HC4 AXLE,REAR,4.56 RATIO 4.56R(HC4)
JB8 BRAKE SYSTEM,HYDRAULIC POWER DISC,DRUM HYD PWR DISC/DRUM BRK(JB8)
LL4 ENGINE,6.2L(6.2J),DIESEL V8 6.2J(LL4)
MX1 TRANSMISSION,AUTOMATIC(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX1)
M40 TRANSMISSION,AUTOMATIC 3-SPEED(THM400-475/3L80) 3-SPD A/TRANS(M40)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
Q1R Unk.
V78 VEHICLE STATEMENT(DELETE)(EXPORT) V78)
XLH Unk.
YD3 Unk.
YD6 Unk.
YLH Unk.
Y5C BODY,MILITARY TROOP & CARGO CARRIER(TYPE B) (Y5C)
Y5F GENERATOR,100 AMPERE,DUAL DELCO 100 A(Y5F)
Y5K Unk.
Y5P MILITARY TROOP SEATS PACKAGE (Y5P)
ZLH Unk.
ZN3 Unk.
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
04U EXTERIOR COLOR,PRIMARY (04U)
