What is the correct oil pressure?
jdeoliveira74
wilmington nc
Ok I did some searching and couldn't find what I was looking for. So what would be the correct Oil pressure for my 1985 m1009. ? Cold /Hot and idle??
Warthog
231
OKC, OK
You have to do a little digging but TM 9-2320-289-34, Chapter 2, section 34 has the pressures listed. This is using the STE/ICE diagnostic unit.
idle - 10psi or above
2000rpm - 40psi or above
From the TM 9-2815-237-34 6.2L/6.5L Diesel Engine Repair Manual
Section 2-34, the following is listed
Underload - 40-50psi
Idle - 10psi minimum
Cold will always be higher than hot.
You can alway look in the Chilton or Haynes manuals and find the same information.
