What size is the crown nut holding the pintle?
TOBASH
3,494
Brooklyn, NY
What size is the large crown nut screwed to the pintle. The really large one.
I was told incorrectly that it is 1 and 3/4. That size socket will not fit so I'm out 50 clams.
Before I purchase another I would like to see what the real size is. I need to transfer the pintle to the pintle extension I am placing on the airlift bum,per.
1987 M1025A1
Thanks In Advance,
T
Action
1,558
East Tennessee
1987 M1025A1
Thanks In Advance,
T
mine is
1.85"
47 mm
remove the cotter pin, clean the threads and unscrew it. It should not be on there tight, unless rusted.
frank8003
4,985
Ft. Lauderdale, Florida
"That size socket will not fit so I'm out 50 clams. "
Is they, |We, Him, Us, not allowed to do that anymore?
Everything you would like to know about your vehicle is in the TM,s
Ask Me, I can navigate thru Tm quick like with all the pictures and absolute particulars
TOBASH
3,494
Brooklyn, NY
Thanks one and all.
I appreciate all the feedback as I was unsure about TM having this info.
RWH, I thank you for the idea about the pipe wrench. I’m like you, but about tools. You usually say when you need a part get the proper part. I usually say when you need a tool, get the proper tool.
I bought and used a 1-7/8 1/2 inch drive impact socket. I had prelubricated the crown nut two or three days ago. The rusted spindle tried to resist, then gave way. I think a pipe wrench might not have worked as I had no leverage with the rear short small bumper off the rig.
Best,
T
Lothar
661
North Arkansas
I see you have resolved the issue but I wanted to share a trick I use often at work to mearsure diameters 20210518_195630.jpgor in this case the size of a large nut. Maybe in the future it will come in handy. By placing 2 squares as shown, you can slide them to fit like a caliper and as long as the bottom edges remain in the same line, you can get a pretty accurate measurement.
Retiredwarhorses
4,182
Brentwood, Calif
Thanks one and all.
Best,
T
Just put a breaker bar into the pintle and crank away, most folks dont have a 1 7/8 socket, but many have a pipe wrench or large channel locks, hit it with some heat and it’s off in seconds. I do a bumper a week, it’s become a tedious process on the M1123’s...
