WHAT'S the answer. Guys I need some help.
mslogr
vaiden ms.
Gotta a quick ? 7155 cat trans oil or trans fluid? Mine seems to not want to shift right first thing in the morn. It acts like it is in a high gear no matter what gear you select, when it does this it will not go into reverse. After it runs for a while it does great. It has oil in it from the military thats why I was asking. Need all the suggestions I can get. Oh yeah I use it to pull loaded trailers out for my road trucks, so with the 920's extra weight she's grossing 100,000 or better per load. That thing doesn't even hesitate on soft ground. Love the trans. Just got to get the bugs out of it. Thanks
NDT
6,530
Camp Wood/LC, TX
My suggestion would be this issue is compressed air related. Any way to send some lube through the compressed air supply line to possibly free up some sticking pistons? I hope this is not a bad idea.
wreckerman893
Possum Connoisseur
15,629
2,054
On that transmission you need to have the air pressure over 100 psi before you even think about putting it in gear.....when you charge the air brakes on a trailer you lose a lot of air sometimes.
Let her build up as far as she will go before charging the trailer or putting it in gear. If the air pressure drops below 80 psi the CAT will kick into neutral. Bad news going down hill with a load on.
mslogr
vaiden ms.
I got that one wreckerman we are able to keep the air at least 120#s. The problem seems to be when its cool first thing in the morn. Once it warms up a little no problem.
Floridianson
2,503
Interlachen Fl.
If you want to back down to a 15-30 wonder if that would help. When warming it up there is 5 gal. of oil in there are you giving her a 5 min warm up.
For a faster warm up when you have air pressure have trans in neutral and push in the slector lock out button and let idle this will limber the oil faster.
mslogr
vaiden ms.
Yeah I've let her idle for 30 min and still didn't act right. Once you get her in a gear and drive a little ways it does fine. I beleive yall are right about the warm up. I'm gonna check on those heaters TATICAL TRUCK was mentioning, if that don't get it will probably thin down the oil.
