Wheel removal suspension drop?
Efituned
Midland, Ga
They're transporting my truck Monday. I have a tire company taking the wheel/tire from the second axle and replacing the busted front tire.
My question is will the hub drop and touch the ground on the middle axle? Or be in the way while loading?
Elijah95
Certified Rookie
1,239
1,184
Georgia
Chain it up, the mtvr doesn’t carry a spare because it’s designed to “limp home” with a busted tire by chaining it up with the axle resting on the upper bump stop
MAdams
127
San Dimas, CA
It might be okay without a wheel and tire. The sway bar might hold up the hub enough. Otherwise chain it up like Eli said
Sent from my SM-G930V using Tapatalk
Efituned
Midland, Ga
Turns out the tire in question is holding air. I sent a guy to the yard to swap out the bad tire and he said all he did was air it up. He went a few hours later and it was still holding. That's good enough for me to at least roll it off the trailer.
