When these trucks are rebuilt are the filters changed?
DeuceDaddy
Waterbury Ct
My 923a1 only has 200 miles on a rebuild from 2012. I just got the truck and I finally have some time to tinker with it. Since the rebuild is so fresh does it make sense to replace the filters? I am mostly thinking of the fuel filter because I'll probably change the oil anyway and the air filter is easy enough to check. Thanks!
Floridianson
2,500
Interlachen Fl.
Engine oil and filter for sure. I have never found a 5 ton filter canister put together wrong only Deuces. I would still do the fuel filter then you can check the canister for rust and crap in the bottom. Also you will know the hours/miles on the fuel filter from the get go.
