where to find a transmission line -
TroyHog
19
Willow Springs, MO
Can you guys point me in the right direction for replacing a transmission line on my 923a1? I believe it to be a return from the cooler up by the passenger front wheel. I am going to try and post pics. Thanks for the help.hose2IMG_7218.JPGhoseIMG_7219.JPG
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
It is just standard hydraulic line with #12 fittings. It is a parker line so any parker store can recrimp it with a splice if it has a hole in it and just union it together.
It is 3/4" hose 2500psi # 12 JIC females on both ends. Any hydraulic shop will carry it. It has a cotton jacket to protect against heat. Little more expensive but not required.
TroyHog
19
Willow Springs, MO
UPDATE: Thanks for the advice - local bearing company that deals with the loggers a lot around here was able to make me up a hose. Cost me $120 - but it did work. The 90 degree fittings were not as long as the originals - so I opted for a straight fitting on one end - it worked fine.
I do have another problem now though. One the way to the trucking place that is putting my digger derrick unit on - she started blowing engine oil out the side of the block - like a lot. Upon roadside inspection it looks like there is a flat plate or some kind of inspection cover maybe - right around where the dipstick tube comes into the block. I limped it in and shut it down - all is ok but I'm going to have to address it before I go back on the road.
Does anybody know what this is and what kind of surface seal it has?
Thanks again!
simp5782
9,339
Mason, TN
Thanks again!
You put the bolts back in it? Your transmission line had a clamp on it that held it there on that plate cover. Remove the 4 bolts and add permaxtex to it. But more than likely you left the bolt out or didn't tighten it down. I've done it before.
Sent from my SM-G965U using Tapatalk
