- 2,112
- 555
- 113
- Davis County, UT
I've seen two different types lights used with towing.
1. This tow light fashion which seems to be the most common and/or standard military item:
2. Composite tail lights on large magnets (not sure how the lights were attached to the magnets and I've only seen them for sale once and I couldn't find any pictures recently). I assume it was "DIY" mod.
I have owned neither and would appreciate your input on them (or other kinds!) as this is part of my research before likely buying a set.
Which style would you want, and why? I can imagine the magnetic lights having the widest array of uses on whatever your MV is towing where a big/flat rear-end isn't present to strap the above #1 tow light setup to, however the #1 option would be more visible with the extra marker lights but also larger, bulkier to store.
Thank you very much!
