Which year 002 Gen?
36racin
11
Gonzales, La
For you guys that have and purchase the 002 gen sets regulary I would like to know if there are any years or manufacturers I should stay away from? I see gen sets dated back into the early 80's to mid 90's.
Also anyone have any insite on the MEP-802a? Good/Bad?
Thanks,
Todd
coyotegray
10
Oklahoma City
The date on the data plate only really tells you when the frame was made and it is even possible the plate has been replaced. Just like the hour meter only really tell you how long the hour meter has been running.
Like most other military equipment, they have been repaired, rebuilt and updated many times over the years.
As far as possible different manufactures, it makes no difference. They are all identical.
Grega
St. Paul Nebraska.
They are all pretty much the same among manufacturers. A couple things they changed in later years, I think the late 80's or earley 90's were a gear reduction starter and an updated a/c regulator board. There may be others but thats what I noticed on the 4 gennys that I have.
Isaac-1
50
SW, Louisiana
Like the others have said there is not much worth mentioning when it comes to the differences over the years, plus the majority of the ones your likely to run across have been through the rebuild process enough times that they are now mix and match.
If you still want to know the common variables I am aware of include:
multiple variants of the diesel injector / injector holder
At least 3 different starters (2 types listed in the manual, plus the new current production Southern Automotive brand replacement starter)
Some / Many recent rebuild MEP-002a's have control cabinets and voltage regulators from the 400 Hz 10 KW MEP112's, these are functionally identical, but have a couple of small wiring differences, the best guess around here is the army found they had a surplus of new old stock MEP-112a cabinets and started using them when rebuilding MEP-002a's
There are also some minor cosmetic differences in the fuel tanks / caps as well as the exhaust pipes, etc.
Ike
36racin
11
Gonzales, La
Thanks for the information guys. The search goes on. Boy the gens up north in PA and Ohio are sky rocketing since the hurricane went thru there.
Thanks,
Todd
