- 34,012
- 1,808
- 113
- GA Mountains
Well, I finally got off my butt and set out to change in inop in tank fuel pump. Not as easy as a cargo since the tank and pump are under the left side of the cab. Figured I'd take the tank loose, slide it out and presto chango! Ha, no such luck. The L arms that supprt the tank are raised at the end. When I tried to pull the tank, it wouldn't clear the rocker, or at least the pump wouldn't. No problem, I'll pull the quarter fender and back tires and slide it back. Ha, no such luck. Can't get it back far enough. Well, just have to drop the 3 L shaped arms and drop the tank that way. Yep, these tractors have 3 where the cargos have 2. Wait, can't get them off, the tank is in the way. After hours of pondering I resorted to the Sawzall and cut a notch in the lip under the rocker. Did I mention you have to smash your arms flat to get to the lines too? Anyway, 4 hrs and close to a unit of blood, I've got the thing back together and running. Just think, changed the one in my old M35A2C in about 10 minutes. I think next time I'll pull the cab! Tomorrow, new J-pipe and new back tires.
