Why not WD40 into the unloader?
98G
Former SSG
4,434
I saw this mentioned in Slate's breakdown thread. I didn't want to hijack his urgent thread for this nonurgent discussion.
I've had an unloader stick. I blew the moisture out with compressed air and then shot it with WD40. Problem solved. Remains solved some 5 years later with no further intervention.
What badness did I risk by squirting it?
Slate
378
Ozona Texas
I had that question as well.
Sent from my moto z3 using Tapatalk
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
There is a procedure for doing it. You can use wd40. Just do not spray it in the unloader. You spray it into the inlet tube and governor. The unloader has no pressure till the governor opens. Let the 125psi of the governor air do the work
Cummins procedure for the air compressor valve unloader cleaning.
-Air pressure should be drained to ZERO.
-Disconnect both sides of compressor and air pressure governor tube and compressor discharge tube
-Spray liberal amount of WD40 into air pressure governor .
-Put a rag over compressor discharge opening .
-Start engine and spray WD-40 into pumping compressor until carbon deposits are washed from the valve.
You will fill carbon and gunk into the discharge fitting and tube by not opening them up. It is smarter to remove the head and unloader. Clean with buff wheel and Berrymans. And reinstall
Slate
378
Ozona Texas
I'm going to try and do this sometime this week. When I took the line off the top of compressor earlier there was no air moving on either side. Maybe it stuck and my Rough Ranch road loosend it up? I dunno it'll probably be a good thing to do anyhow.
  • Like
Reactions: 98G
Elijah95
Certified Rookie
1,239
1,196
Georgia
Wes made his comment specially for me, on recovery of my M923A2 from Houston, my unloader failed me and wouldn’t allow air to build. Upon slight disassembly, we found there was lots of nasty stuff in the head. Sprayed some aerokroil oil in it and we got back on the road!
Months later, same symptoms so I gave it a squirt. Problem solved. Then my O-rings crapped the bed inside the head from the solvent based lubricants I was spritzing it with, rebuilt the top half of the compressor as a result. If it’s an emergency get home fix, spray it by all means. But just know you’re going to tear it apart at the worst possible time!
Unfortunately spraying enough oil in the top of the compressor where the unloader signal line belongs it’ll sit there and cook in the compressor until it carbonizes
