motormayhem
- 6
- 18
- Tucson, AZ
Runs around the 190* thermostat when temps are below about 90*. For temps between 90-105* it will run about 195-200* in traffic or at lights, about 200-205 down the highway, and as high as 210* on long hills. Has a new water pump, thermostat, fan clutch, and radiator was fixed and cleaned about a year ago. The only not stock cooling system piece is a 10"x18" transmission cooler mounted right in front of the radiator (see pic), but stock blazers had a/c in front of radiator so how is that different? Whats causing my temps or are they ok for 100* weather?
Thanks,
Motormayhem
Thanks,
Motormayhem
