Winch cable socket pin dimension?
cranetruck
75
Meadows of Dan, Virginia
In the clevis/shackle world, the pin diameter appears to be a measure of its capacity, so accordingly, I'm trying to determine the actual rating of the cable socket/chain/hook assy on both the deuce and the 5-ton winches.
The chain/hook on the 5-ton winch is only rated 12,000 lb or so and the pin in the cable socket has a diameter of 1.0 inch giving it a rating of about 13,000 lb.
Conclusion: The 20,000 lb winch should never be used to safely pull anything over 12,000 (plus or minus). To increase the rating, the cable socket must be replaced along with the chain and hook. Anybody see anything wrong with that?
The deuce uses the same chain/hook assy, so it's rating is matched with the winch.
Question: What is the deuce winch cable socket pin dia?
Thanks.
avengeusa
MI USA
The pin in the socket is 7/8 inches in diameter for the deuce, the whole thing is rated for 26,000 lbs
I have the specs on all of the different sizes, and have sockets on the way to me nib cheap
The 5 ton socket with a 1 inch pin is rated at 41,200 lbs
cranetruck
75
Are you not talking "breaking strength" here, the clevises, hooks etc are marked with a "safe working load" (SWL) as should be the winches.
cranetruck
75
Okay and thanks for the deuce pin info.
A shackle with a 7/8 pin dia (Crosby Group) has a working load limit of 13,000 lb, for example, which matches the deuce winch.
Some tables show a higher rating, some a lower, so it's very much a matter of which safety multiplier used.
The "Rigging" TM 5-725 has safety factor for chains, which is 1/6 of the breaking strength.
BEASTMASTER
142
Burgaw, N.C.
i've been in consruction for over 40 yrs. and done my share of getting stuck and pulling stuff out. i've constantly used shackles with a 1 in. pin and 5/8 cable and others . i've pulled many loaded tractor trailers 120,000 lds out of the mud and sand with 5/8 cables ,5/8 and 3/4 in shackles and never had one fail on me. maybe just lucky
jasonjc
288
Gravette Ar.
Look at the working load on the cable it's less than 10,000lbs. for the deuce.
The sockets are rated EIPS breaking strength not working load.
rosco
Delta Junction, Alaska
Its easy to get bogged down with all those ratings. Where they are more important, is in "overhead" crane type work. When your bogged on the ground, and your rigging looks a little light, its easy to compensate, by making a double wrap, or using a snatch block, and "heaven forbid", even a shovel!
Lee in Alaska
