F18hornetM
- 10
- 38
- Ocean City, Md
Finished installing winch but was missing a couple parts. The top cross piece above the winch drum, lock plate for PTO shift lever and of course gaskets, studs and ubolts. Found studs and ubolts at Napa easy enough, but decided to make lock plate and winch bracket. Couldnt find a good picture of a lock plate, so just built my own. Wanted a small hinge so used 3" x 1/4" solid rod, and bored 1/8" hole in it on lathe, then cut in 3 pieces. Installed 1/8" pin and welded to opposite parts..Homemade hinge..bent up left corner to get finger under to better to lift when down on floor. Pipe can be used for hinges like these, but I like solid rod drilled out. Makes for better pin fits and you can use make hinges of any size.
The top piece of the winch I made from 10ga sheet metal, and bent on brake to make a piece of channel. Think it looks close to pictures I've seen.
