Edward Stephens
- 0
- 0
- Eastern NC
I just scored a M54 to use on the farm and in the woodlot. It does not have a winch, I am going to add a PTO and winch. What is the ratio on the pto? I have a 5 direct transmission. The reason I ask is that I may use the winch pto to run a water pump for a while and then install the winch when my project is completed. I dont want to use the accessory drive pto because I am cheap and the pump needs to be mounted topside.
My truck has a multifuel engine and I would like to add a 120v engine heater, either an internal one or a heater hose model. Have any of the members got a favorite heater? This will end up being the "Man we are stuck bad, go get the big one" truck.
And lastly thanks for all the shared knowledge on here, I have done tons of reading on SS before buying my truck, I needed a cheap tough truck to spray cutover pine land as part of my reforestation plan. 6x6 for $3000 cannot be beat/
