rtadams89
- 3
- 18
- Phoenix, AZ
M35A2 with winch. When I bought the truck, I found the winch shear pin had been replaced with an undersized bolt. I removed the bolt but couldn't get the holes to line up to put a correct shear pin in, so I left it without anything and figured once I had the winch actually attached to something, I could turn the shaft and get things lined up. Well, I used the winch to pull a tree over, and even without the shear pin in, the yoke and winch shaft are stuck together (at least enough to pull over a medium tree). So, now I'm concerned. I tried soaking the joint in penetrating oil and vibrating it with a light air hammer, still nothing. I then disconnected the drive shaft and tried to pry the yoke off without luck. What's my next step? Cut it off and replace? Any advise for how to cut it off without damaging the winch drive shaft?
