Wiring battery tender on M1008
Maggie86M1008
Nebraska
I would like to hard wire a battery tinder to my M1008. I've read where I can use a 24 volt tinder or 2 12 volt tinders but can you use one 12 volt for both batteries? If so, how could I do this. I did try searching but really didn't find anything. Thank you.
MarcusOReallyus
816
Virginia
Run the ground lead to vehicle ground, run the 24v lead to the 24v terminal (the + terminal) of the rear battery, or, better yet, the 24v bus bar.
Maggie86M1008
Nebraska
Will doing this also charge the front battery too or just the rear battery?
Keith_J
1,319
Schertz TX
Both batteries will be charged with this method.
1,808
You can't run one 12V tender for both batteries as long as you have them wired is series (as designed).
Maggie86M1008
Nebraska
So I run the + lead from my 24 volt battery tinder to the 24 volt bus bar and I run the ground wire from my 24 volt tinder to the ground bus bar - is that what you're telling me? And this will charge both batteries? Thank you
Maggie86M1008
Nebraska
Thanks very much guys - really appreciate it. I will go see if my parts store has a permanent 24 volt tinder and see if I can get this job done today.
