Hi
I have a 1986 m1028, i was adding some gauges and also doing a bit of clean up (removing alpine radio with large wire bundle and other old sins) but now it wont crank over, sometimes it does nothing when i try to start (only dash light dampens out like usually) and sometimes there is some bad sounds coming from the hood but no cranking. All the dash lights and everything else look like normal, only when i try to crank there is a problem. Luckily there were not to many wires i was messing with so hopefully ive not done to much butchery, see photos below:
I made these grey wires longer with a blue wire just so it was easier for me to check their voltage and such. The picture of the wires on the floor i cut out of the truck to shorten the grey wires, those got connected to the black hole that was the radio and a switch to turn the radio on and such.
Ive looked over the wire diagrams but im not able to read out what i need.
