would you drive on this?
Kohburn
SOMD
I don't have much experience with tube type tires, won these on ebay for the cost of shipping but didn't expect to see so much dry rotting on the sidewalls.
I put a gauge on them and they are all aired up to ~45psi. I only removed the valve core from one to attempt a tire dismount.
8 goodyear SRL-1's and 2 Kumho power-lug's in 11r20
safe to use? or did I just throw away some money ($700 in shipping)
(and yes i brought them home from the delivery in that tiny trailer pushing its weight limit)
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I would see how they look when aired up. If that IS aired up, I'd use them as rears and be real nervous if they were on the front. Fronts are important, the rears are not as important. Especially if dualled.
Josh
12
Portland, Oregon
Those look better then some of my tires. As long as the cuts arn't deep, I dont really see to much issue with them. I wouldn't max out on the weight though.
jdknech
Jeffersonville, Indiana
those are not bad at all!! if you have to change rims, be VERY careful airing them up, i watched a ring come off one my dad was doing when i was 8, that's something i will NEVER forget... i would put those on the rear, and not think twice.. just my2cents
stumps
12
Maryland
By the time the sidewall starts cracking like that, the cord could be compromised. It isn't meant to be exposed to the elements... I have run radial tires with small splits like that, and had them rip the side wall when I hit a pot hole. Also, if they are dry rotted around an area that was parked on the ground for a long time, the tread will often tear off.
Tubes let you get a way with worse weather checking than tubeless, but a sidewall split will put you out of business either way.
Off road I would run them until they disintegrated. On road I am a lot more cautious.
-Chuck
Varyag
Garfield, Washington
I would use them as farm tires but not something that might go on a road and have you swirv into on coming traffic. Just my two cents. I am pretty careful about what I drive down the highway.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
I would not use them on-road. Considering half the people in 2 pages said the same should say something as to whether use them.:rant:
