TexRdnec
- 0
- 0
- Sinton, TX
got a pinhole in the damned thing that i just noticed but no, the cap is holding fine now and it's not using coolant at all
the pinhole is on the backside of the radiator, about it the middle closest to the drivers side. theres a quarter sized wet spot and about a 5" sized section around it that's corroded from it.
so far as i can tell i have fixed the IP oil leak. however, that jet black crud coming from the turbo is oily..........
Tooling around your place at 10 MPH doesn't put a real load on the engine. It doesn't take much more fuel to spin the engine at 1800 RPM than 800 RPM, most of that additional load is from the fan. And 10 MPH takes all of 3 Hp, give or take.yes, always under 10mph but the truck shouldn't have known it............was almost always about 1800rpm. might even be from the ****ty diesel?
can see the wet spot on the radiator. the sealant stuff wouldn't hurt the block? cause it's got to be small enough to be an easy fix................
