X-door Scratched "Glass" Fix
captcarc
Canton/TX
I've read other fixes for the scratched glass x-door inners including replacing. After disassembly, the total thickness of the laminated window was 3/8". I was thinking that the outer layer was 3/16" glass and the inner layer was 3/16" plastic, but this was incorrect. There are two glass layers with a very thick plastic "film" on the inside surface that was heavily scratched. That plastic film can be easily peeled off leaving a beautiful window, glass on both sides, that can be reinstalled. Beautiful! (Window must be disassembled to remove film.)
Milcommoguy
2,216
Rosamond, CA
That's true, BUT it maybe a little loose fit. I had to wrap the edge with tape , trim it to hide in the channel taking up the differance.
Now I can see clearly too, CAMO
Mogman
9,307
Papalote, TX
I am wondering why one can't just take a razor knife and cut around the inside of the window frame? No need to disassemble and the glass will not be loose...
I will have to look but I think that was actually done to one of my windows, there was allot of glue residue on the inside of the glass, there are also some cracks in the glass which is allowing the plastic between the glass plates to delaminate so I am going to need to replace it.
TOBASH
3,425
Brooklyn, NY
I like this thread, and I like the OP posting it, but just to play Devil's Advocate, let me present the following:
Unless the inner window plastic is bubbled, it can be polished by a marine shoppe, the same way they polish clear plastic windows on a recreational boat. You can even do it yourself.
Best.
T
captcarc
Canton/TX
I think there may be different window substrates. If yours is 3/8" thick, like mine, it may consist of two laminated glass plates with a thick plastic "film" on the inside. Your proposed idea of scoring and removing the inner plastic layer will certainly work and avoids the disassembly. I am disassembling all doors anyway for painting and detailing so it's easier to just remove the whole plastic sheet. I have no concerns with the minor reduction of thickness of the finished glass.
TOBASH
3,425
Brooklyn, NY
I did some investigating. The inner plastic is there to prevent glass shards from being expelled from the window into your eyes in case of breakage.
Knowing what I now know, I would get the plastic cleaned and polished at a marina that is experienced with plastic windows that fade with time.
captcarc
Canton/TX
Good luck with that. It MAY be a coated polycarbonate that would not polish well. My windows are now sparkling clean and clear and I don't fear glass shards.
