Xtra tall M105a2
machinist75
Murphy, TEXAS
I got an xtra tall cargo cover from a buddy of mine that was 20" taller that the original one. So I needed to raise the uprights. I drilled out the welds that attached the bow corners to the original uprights. Cut 10pcs of 1 1/2 square tubing 34 3/4" long notched the bottom on a cnc mill and then re welded the bows back on. The inside is now tall enough to stand up in with a few inches to spare. The only thing is that it's about 3" taller than the deuces cargo cover. Hopefully it dosnt affect anything. Need to paint the trailer now.
rosco
30
Delta Junction, Alaska
Looks sharp! What will you use it for? The only thing I would be concerned about (and maybe you have addressed it already), is the large expanse of unsupported tarp, on the front of the trailer. Is there an expanded headboard too, to support it?DSCN4701.jpgThe tarp is really worthwhile, so I made a little frame and expanded frame, on my MEP trailer, to help support it, when on the road, so there is less stress on it.
(I sure don't know how to get these pictures and text lined out better!)
machinist75
Murphy, TEXAS
Looks sharp! What will you use it for? The only thing I would be concerned about (and maybe you have addressed it already), is the large expanse of unsupported tarp, on the front of the trailer. Is there an expanded headboard too, to support it?View attachment 408136The tarp is really worthwhile, so I made a little frame and expanded frame, on my MEP trailer, to help support it, when on the road, so there is less stress on it.
Thats a good point. I will need to do something to tie it all together. Maybe a brace going from about midway up the first upright to the base of the second at a 45 degree angle. What do you think?
machinist75
Murphy, TEXAS
Oh now I see what you mean. The void in the middle. I think I will do the brace like I said above and a few more-headboard slats going horizontally across the front.
