Year of Mfg?
CatMan
10
Denmark Wisconsin USA
CCKW Year Of Mfg
Serial Number 185195 would have been built in December 1942. There is usually a letter in front of the -2 you discribe. After the 6 digit serial number, a dash and A2 means Cargo Body without winch and banjo type axles. B1 means Cargo body with winch and split type axles.
Does your truck have banjo style axle housings? That is what the "2" indicates.
Go to the www.CCKW.org web site - much more information on the WWII GMC.
Cat Man
D6c
14
IA
It has bango axels...I looked in the TM and found that the -1 or -2 serial number suffix without a letter designation indicates that it came without a body from the factory. I hadn't noticed that before.
Mine has an all steel cargo body but isn't painted same as the truck. No doubt it was added later.
