yet another glow plug issue
Dmoser
Rapid City, SD
Iv had a cold misfire for a while now and finally got around to finding which glow plug was bad. Cylinder no. 3 was open so I went to NAPA and got a 60g plug. The blade turned out to be a lot bigger than the one that I pulled out so I had to shave a little bit off the sides (probably not a good idea) to get it to fit into the terminal. I installed it, cycled the plugs and the miss was still there. I checked the resistance of the plug after shutting the engine off and it was at 16 ohms. The tm says it should be 3 to 4 (or something around there). Kinda confused by the problem. Any suggestions?
Dmoser
Rapid City, SD
Hmmm. Seems weird that that would only happen for the first couple of minutes right after a cold start up. I knew the plug was bad already but I guess its not out of the question for it to be an injector. Really hope its not though
ranchhopper
139
south elgin illinois
I have one on the driver side that misses at start up and that is the only side that I get smoke from on a cold start so I figure its an injector I can hear it faintly when the engine is running too. I have several 6.2s sitting here to take one from I just need the ambition to get it changed out.
HeadWizard
Chantilly, VA
Agree with Ranchhopper, had that happen on a couple of our older 6.5 mechanically injected p/u's. Bad injector. Sucks but will fix the problem.
Dmoser
Rapid City, SD
Well then I guess the next step is to find the bad injector. Then wipe the egg off of my face and tell my shop foreman that he was right :p
Wolf.Dose
9
Boehl-Iggelheim, Germany
Normally bad injectors come up over 200.000 miles due to the low injection pressure of 125 bar or 12.5 MPa. The wrong register if the plug says it is the wrong plug. However, the engine normally starts properly, if only one plug works fine. the other issue is the pre glow card which usually failes at some 120,000 miles. Change of the card to a good one will help or replace to hand glowing of max 6 seconds or you will blow the original plugs!
Wolf
Dmoser
Rapid City, SD
Engine has just shy of 79k on it. Pulled the card yesterday and it looks like it has a burn mark on it. Been had to wire in a push button for the plugs a while back because they weren't cycling.
acesneights1
21
20
CT
You never know how long a CUCV was idled and idling kills the nozzles so mileage could be irrelevant. They squirts should be changed at 100k under normal usage as proper PM. Of course many run them much longer but a bad or dribbling squirt can ruin a piston.
Pballer71
Michigan
My m1009 has a problem with starts some times it starts fine others i have to cycle it a few times so my dad and i got new glow pugs for it and its still doing it could it be the injectors
