Heavysteven
- 10
- 0
- Hickory Flat Ga
Wow nice build
Will try to get P/N & specs but consider that this is stuff made in Argentina, so prob not many chances to find them in your region...?G' - do you have a PN or specs on that spool valve? I do like it's size, but have a concern that it may be quite restrictive on the flow side.
Interested, though...
I think you are talking about possible radial runout and misalignment of the two shafts..........I gave it a couple complete rotations to let everything settle in before tightening the mount onto the winch. I really don't know if this helped, but is the best installation method I could think of to obtain decent alignment. We'll see how I did...
I'm kind of with G on this. I'm worried this may damage your motor over time. There's going to be some end play on your winch shaft when switching from forward to reverse.Not really very much. I did think about this when I was test fitting. Final fitment was pretty snug. I actually left the motor mount loose on the winch, aligned and tightened the motor onto the mount, and let the shaft coupler do the final aligning. I gave it a couple complete rotations to let everything settle in before tightening the mount onto the winch. I really don't know if this helped, but is the best installation method I could think of to obtain decent alignment. We'll see how I did...
ah, I understand what you're saying. For curiosity sake I'd like to now pull up the winch parts drawings to see what style bearings used to control axial thrust. I'll have to get back to you on that.... I think you are talking about possible radial runout and misalignment of the two shafts...
What I mean is slight axial movement with eventually tons of force from the winch shaft transmitted axially to the motor shaft via a rigid coupler! I believe that that part should not fit tight on the motor shaft. Best if it was a splined joint, of course.
G.
no - it's from the repower and is completely above the frame rails and not between. however, the motor does [obviously] occupy the space that the OE drive shaft does, and therefore the area in the radiator that has been clearanced to accomodate this.You're not running the stock radiator are you? I know I've looked at this before on my stock A2 and there didn't look like there was enough room to install a A3 hyd motor with the stock radiator.
To maintain 25 fpm line speed on bare drum (which may not be necessary) the motor will need 20 gpm.... Anyways, for that motor, what would be the max. required flow in gal/min at 2000psi? ...
I honestly think that you're going to be hard pressed to readily find a 20k lb hydraulic winch in the 'affordable' neighborhood.how much can the A3 stuff be picked up for vrs selling the stock winch and going with an aftermarket winch rated at or more then 10k?
Yes, the radiator is cut out but I don't think it's cut out enough to fit a hyd motor. I'd be interested in the motor dia. In the pics it looks too big to clear the radiator. That's not saying a hyd winch wouldn't work on a stock A2 though. You'd just need a shaft and mount the motor to the truck frame rail.no - it's from the repower and is completely above the frame rails and not between. however, the motor does [obviously] occupy the space that the OE drive shaft does, and therefore the area in the radiator that has been clearanced to accomodate this.
What I can do is measure the motor diameter and approximate location for anyone interested in whether this motor will fit in the same void.
Don't be surprised to find std. #6309 ball bearings there (TM9-3830-206-34P, fig.2, item #6); on a shaft that is subject to over 4-times the maximum recommended axial load for that particular bearing!.........For curiosity sake I'd like to now pull up the winch parts drawings to see what style bearings used to control axial thrust. I'll have to get back to you on that...
No. They would tell you to replace the bearings if there was any significant runout to be felt... Although it does specify minimum axial end play for the wormshaft: 0.005 in.you think the -34 will give shaft runout...?
I'm thinking you're correct. Motor diameter is ~4.5"; it is located approximately 7" in from the inside of the frame vertical web with a total width of about 9.25" from the same location. It's hard to figure the top since the OE radiator is no longer there, but there needs to be about 5.25" vertical clearance as taken from the top of the forward edge of the front crossmember.Yes, the radiator is cut out but I don't think it's cut out enough to fit a hyd motor. I'd be interested in the motor dia. In the pics it looks too big to clear the radiator. ...
For sure!!!Travis, ... Why are you going to all of this time, effort and EXPENSE to convert from mechanical to hydraulic and back to mechanical again? Is it just 'Cooler'? ...
The answers should be Yes, The same, and Yes. Mainly, I'm after the 'safer' part; the hydraulic winch cannot be left in either Pay In or Out by error or default. Therefore, the hydraulic conversion is more condusive to safe winch operation by a solo operator.... Is a hydraulic winch faster? stronger? safer? ...
Not really. You see, I had the option when I swapped in the new transmission as a part of the repower project. There is a gear drive PTO box available for the NV4500 transmission that would perform almost identical to the OE PTO box that was being replaced. However, for the overall cost of the NV4500 PTO transmission and custom driveshaft it would have been similar to the cost of hydraulic conversion. And given the increase in flexibility of operation and safety factor when accomplished by a solo operator it made sense that the hydraulic conversion was the best choice for me.... Seems like you took a very basic, simple PTO winch and made it very complicated. ...
Sizing the pump to the motor needed to be done carefully. I used a PTO calculator spreadsheet that was made by a company that speciallizes in doing such hydraulic conversions. I had to do some research on finding the specs of the A3 motor that I had acquired.
