6.2L work
bjsmith
zachary,la
not sure on price for everything might can find drop out 6.5 for good deal take what you need and sell the rest could even get everything to make it turbo all will bolt on i sold my running 6.5 out of my 3/4 ton for $500 coplete with all acc would just have to search and find the right deal only reason i pulled was to swap in 5.9 cummins for more power and better mpg and to me better engine
bjsmith
zachary,la
i seen you said something about a aftermarket turbo kit instead of it just find you a drop out take everything you need and then sell long block to get some money back. i see alot of people looking for them
jdeoliveira74
wilmington nc
it came with crank pully and water pump pulleys. You should be able to find alternator brackets and ps brackets in junkyard civi blazer or k series truck use same brackets!
Warthog
232
OKC, OK
Post an ad over on one of the diesel websites. You will find alot move people with the brackets you need. Altought you can use the CUCV brackets, the civvy version will better suit your needs.
You will need the 6.2 or 6.5 brackets. The gasser brackets will not work without ALOT of modifications
www.thedieselpageforums.com
www.dieselbombers.com
www.4btswaps.com
The cost should be between $200 and $300
If you do go to the serpentine setup, the water pump is different as it rotates in the oposite direction.
461
Sandyston, NJ
The serpentine water pump off the latest civy 6.5 is the most eficient. It provides the best cooling for these engines and it is serpentine specific as it rotates oposite direction. cooling is a big factor with these engines. if you over heat just once then you most likely crack the heads. If you find a civy 6.5 everything for the accesories and the water pump will bolt on. you will also have the intake and exhaust manifolds to use as well as the complete turbo set up. All bolt on.
