rolling18
- 77
- 28
- Portland, OR
#1 question I get from everyone!!What are you going to do with "That".
answer: Drive it!!!
The plan is to make the camo job go away in the spring andNice truck. Interesting camo job. Have fun.
I agree but with winter here and only gods garage my thought was to get here sealed up till spring.Take down the hubs the first time and put non-zipper boots. That way you know what you have. I took mine apart to find the grease was brand new on one side and half brand new on the other where the inside bearing was not repacked when the hub was removed. No issues save one race had a mark on it and needed to be changed out with a new bearing and race. I also changed all the seals while I had it apart.
The main thing is that now I know what I have.
There would be a large box over the driver side inner fender (under hood) with two coolant hoses coming over the front top of the engine across the oil filters into a heat exchanger.
LMAO, same here.#1 question I get from everyone!!
answer: Drive it!!!
