Clay James
- 4
- 18
- Reno/NV
Been working the past few months on this project and took pictures along the way so I thought I'd post some up.
My buddy and I decided it's time to completely overhaul our brake systems. His turned out to be really bad. The soft lines all had cracking and the brake fluid that came out was black and gray. One of the brake pads on the passenger side front wheel wasn't even working.
Both of our front axles were leaking too. I had redone mine a few times already but it still leaked so after some research I decided to replace my spindle and kingpin bushings. The spindle bushings had a lot of play and the knuckle had a lot of end play. I didn't know too much about this stuff last time(probably neither did the military mechanics when they had it) so this stuff went unnoticed before. After doing this job 4 times now, I'm very familiar with the Rockwells
So the total job is, front axle seals on both trucks, new wheel cylinders on his truck and rebuild mine, new master cylinders, new soft hoses and a few hard lines that rusted, new knuckle boots, repack all bearings, remote brake fluid reservoirs, rotate tires on my truck, new starter solenoid on my truck(still clicks just as bad), new front brake pads on my truck, two new races and one new bearing on my front axle, rebuild the air cylinder on my transfer case, new parking brake on my truck. I'm doing all the work now because my buddy got a boat he's been working on. I get paid in M855 though I was a little too optimistic thinking a few weeks was all it would take. I started back in October.
