Sprag modification to Manuel Lock-In
porkysplace
1,493
mid- michigan
ODdave is right, you can get the setup you need for reasonable, in fact, i could set you up with the case and everything else you need for $350 if you want to make a drive south :)
Have tried downloading the from the resources section here ?
HASSON1911
24
roseau/mn
Well, I would love to look at the TM but it doesn't load on the computer, also i don't know where the mutiny is coming from I just wanted to make sure we were all on the same page.:| Also MY mistake its not a shear pin but a key! Sorry for coming off stubborn just like to make sure everyone is on the page before i start throwing ideas out- It's burnt me more than once.
porkysplace
1,493
mid- michigan
If your computer won't download the TM's you need to spent $5 and order the cd of TM's off e-bay . If your going to own a military vehicel you need to have the TM's.
1,132
Its off topic but do you have any luck googling TM's? My computer dosnt want to download them from jatonka. I have the paper ones but didnt feel like going to the garage last night and had zero luck just using a search engine. Is there a website that dose not require downloading?
We have them here, have you tried downloading them from here?
I downloaded all of them and when I am doing a job, I print the relevant pages and tape them to the truck and when I'm done, throw them away.
I've had no issues downloading them from here or jatonka's site...................... I assume you have Adobe Acrobat installed?
I have looked and never seen TM's uploaded in a full, readable (non downloadable) format.
ODdave
41
lansing michigan
Yes, I have tried downloading. I think the problem is with my computer. I have the paper ones, Just was curious if there where readable ones without downloading. Thanks guys.
73m819
325
gainesville, ga.
MEMPHIS at one tine had a kit to eleminate the the deuce surag, it worked with a lever to engage/disengage, and parts to replace the sprag,
bjsmith
zachary,la
i have the reb kit i just bought from a member to replace my sprag i havnt had time to install yet but will be installing soon it has new gears and shifter looks like it will work good only time will tell
73m819
325
gainesville, ga.
What about taking pics of the parts of the kit, maybe scan the the instructions, and do a bit of a write up on the kit, i would guess a LOT of sprag owners would like to see how the kit was done :beer:
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Go ahead, blame it on the shear pin. Shear pins get all the abuse and no glory for the countless $$$ in parts they save. Shear pins are like the red headed step child of the industry.
porkysplace
1,493
mid- michigan
Post number 15 has a link at the end of the post , for a thread on the REB kit it has pictures in that thread.
doghead
4 Star General /Moderator
1,179
The first issue I would solve is, how to download(and save) the TMs.
HASSON1911
24
roseau/mn
that is my kit thats the guy i bought it from just have to install
I forget who supplied the pics, but thank you very much! my dad understood it all the second he saw the pics, but it was greek to me. So now, my job is to find the proper gears and spacer and other essentials to slap it in. I thank you guys for your help even if you think i came off stubborn, sometimes I need it I guess its my thick German/Swedish skull! :beer:
ODdave
41
lansing michigan
Na, your fine. Your learning.
Were just a groop of grumpy sh!ts....
