Major engine oil leak
deathrowdave
81
falmouth, ky
Follow the return tubing from the injectors . Should be connected between 3 front and 3 rear return lines. It is located on the passenger side near the intake manifold directly above the turbo. Should be able to blank inlet and outlet tubing with 1/8 NPT caps. Search Intake Fuel Heater , many pictures and help on this .
RIDDLE1
Americus GA
Thank you so much for the help.
