Iceman3005
- 96
- 28
- Holt, MI
Harmonic balancer has been clanking for a couple of weeks now so I finally got a new one. Took the whole front of engine area apart to replace, went very smoothly so I put everything back together. Started truck up to test it out and warm up for an oil change, things sounded a lot better. After a couple of minutes I noticed a small drip coming from bottom of balancer, thought maybe the seal was installed incorrectly........nope its not, oil isn't green..........? that's nice its the water pump leaking, then about 2 minutes later (truck still warming up for oil change) the right alternator starting to squeal and the pulley started banging (moving) around, then the left alternator started to make a low whine and the belt started to squeal
. So after all the work taking apart and putting everything back together for the harmonic balancer, I had to take everything back apart, and on top of that the other cucv's front end is all torn apart for a axle rebuild, so now both trucks are down.................man this stinks.
![Doh! :doh: :doh:](https://www.steelsoldiers.com/images/smilies/smiley_doh.gif)
