Funny GL Photo
armytruck63
10
Redlands, CA
I never knew rabbits climbed up into engine compartments (rats, yes) UNTIL I started up my deuce after it had been sitting in a field for a while.
Score: Deuce 1, Rabbit zero.
mckeeranger
Eastern Kentucky
You could take what's left, mix it with the right spices and BBQ sauce, let it simmer for a while then put it on a bun.
Hoppy Joe sandwiches! :beer:
wdbtchr
St. Louis, MO
Might I suggest Lousiana Hot Sauce painted on wiring harness to keep the critters from chewing on the insulation. Also works well when applied to the same critters after cooking.:roll:
hwcurtice
35
Moncks Corner, SC
I found the listing in question, only because I search for that model truck all the time. Hopefully, I can find one closer to home that still runs...
Anyway, GL posted two pictures with Ms Bugs in the engine area sitting on the air cleaner. I think she thought she couldn't be seen...
USAFSS-ColdWarrior
Chaplain
5,752
I suppose you're declaring a RSHTF Event has occurred under your hood?!?!?!?
I agree that the Lot should be refused by the successful Bidder IF the rabbit is missing by the time his EUC clears. Either REFUSE the Lot or File a Claim for a value adjustment.
MISSING RABBIT - that could be a hare-raising shocker!!!
:driver:
2,419
:driver:
It is "possumble" that you are all jumping the gun just a hare?
I think we should just "bear" with GL until the auction is over.
USAFSS-ColdWarrior
Chaplain
5,752
PB,
You raise a valid point. I'm "ALL EARS". Yet I don't think that the best tactic is just "Grin & BEAR it". If the bidding doesn't HOP way up there pretty quickly, that bunny's just gonna "High-Tail-It" outta there. Maybe some Hugh Hefner-esq moves on that little Cottontail would help.
I haven't read the auction description on that Lot, but if it's a hard-to-start CUCV then maybe, just MAYBE that furry-port on top of the air-cleaner is for injecting some EASTER into the intake on start-up. Think of it as an EASTERBUNNY INJECTION PORT.
(OK - I admit that second paragraph sounds pretty lame..... Oh well - posting without deleting it anyway.)
