Harleyd315
- 5
- 18
- Denville,New Jersey
I have an 003 that I have gone over and got running. It starts up and smokes a bit till it warms up then clears up as the engine gets warm no load. I let the motor warm up and load tested the set, 4 mins at 75% load I heard a small pop and saw smoke coming out of the area of #2 injector. I pulled the injector saw some exhaust residue on the side of the injector and ordered and replaced the injector seal. The motor again fired up ran with a little smoke but cleared up after warm up. Put a load back on the set and after about 5 mins I got smoke out of the front exhaust pipe again. The engine almost sounds like it may have a small miss. Shut it down, let it cool off pulled the valve covers off and checked all the valve clearances. All were a little on the loose side so I snugged them up and fired the unit up again but no differance with a load on it, it still smokes. I looked at the desert tan paint on the exhaust pipes and the front one is a different shade than the rear pipe. I took my infared thermometer and found #2 cylinder to be about 150 Degs F hotter than the other cylinders. The smoke is a whiteish color not black. I was wundering if anybody has any similiar problems with thier sets? What should I be looking at the injector or the IP pump? Can something stick in the pump on just one cylinder or should I try an injector first? Also some members have talked about copper gaskets for injector mounting, the one I removed was a metal/fiber type material similar to the exhaust manifold gaskets I have replaced on some heavy equipment. Which is correct, copper or the metal fiber for where the injectors seal against the head. Thanks for the help.
