greenjeepster
- 9
- 0
- Southbury, CT
Because this question comes up all the time I thought I would start an easily searchable thread with measurements in it.
So the Maximum drive leg room in a Deuce with a spring seat is 38 inches. That is 4 inches less than a 2001 Geo Metro. This was measured with the seat all the way back and the lumbar support all the way in. Measuring from the base of the fuel peddle, to the front of the seat you have 21 inches.
There are several adjustments that can be made to the spring seat.
Lumbar I already mentioned and can be adjusted to gain 2 inches.
The base of the seat has two adjustments to it. The first angles the rear of the seat upwards or down and the second angles the front of the seat upwards or down, the second can gain you one inch in leg room from the peddle to the front of the seat, but does not change the overall Maximum leg room of 38 inches.
The tension of the spring can be adjusted using the crank on front of the seat, this also does not gain you any legroom. It just serves to increase or reduce the amount of bounce in the seat.
You can alter your positioning while driving by occasionally adjusting the back or base of the seat. This will aid in comfort over a box style seat as you are able to shift how you are sitting without physically having to shift yourself in the seat.
