oddshot
- 116
- 43
- Jasper, Georgia
The easiest way I've found to separate oil form water or antifreeze is to mix in little gasoline ... perhaps as little as 10% ... and let it sit overnight.
You don't even need to agitate it ... just pour in the gasoline and it mixes by itself.
Batch size doesn't seem to matter.
Yesterday, I took a sample of a pink milkshake I got from a trans shop in the and put some in the two jars below. In the first on I poured a little gasoline... I didn't put anything in the second jar ... and I let both jars sit over night.
You can see how the batch with the gasoline in it separated out the water and antifreeze.
As a further experiment ... today I poured the two jars together ... I'll let the mix sit overnight and post the pictures tomorrow.
