Just a thought, before you try to start, turn on the master switch, get out and crack the bleeder on the secondary fuel filter housing, see if you get bubbles or a nice fountain of fuel. Then close it off, and try to start it. Also, I have to use about a quarter-pedal of throttle to start easily.
One other thing, I think with the multi-fuel's system, you can leave the in-tank pump running for five minutes and it will bleed most of the air through the return system, if there is any. I just changed all of the filters, and replaced a couple of the lines. The only bleeding I did was at the secondaries, along with running the pump to prove out my manifold preheater. I could hear bubbles moving through the system for several minutes. When I did crank her, she started right away.
