hydraulic head torque
Josh
12
Portland, Oregon
I'm in the middle of putting my IP back together and somehow lost my page with the torque specs. I can't get my phone to open up the tech manuals. Anyone know the torque spec for the 4 bolts that hold the HH down. Tried search but all it would pull up are the torque specs for the actual heads.
Thanks for the help.
doghead
4 Star General /Moderator
1,179
Probably could not read the tag on the HH with his phone.
Josh
12
Portland, Oregon
I thought that spec was for the injection lines. Not those 4 bolts. I ended up just torquing them to 25 anyhow and when I get home ill double check the manual. Before I start it.
When I read tubing nuts - 25ft lbs, that sounds like the injector lines to me.
sandcobra164
295
Leesburg, GA
I just put a HH on this afternoon. How in the world could you torque them if the rest of the injection pump is on the truck? Good Job though, not many Deuce owner's have pulled a HH!!
Josh
12
Portland, Oregon
A deep well 1/2 socket, universal joint , short extension and a torque wrench. Getting those 44 bolts are by far the easiest part of it. I'm just hope it all went back together good. Ill find out in the morning.
