camoyj7
- 18
- 18
- wonder lake IL
Lost oil pressure on my 6.2 diesel when I started it up sat morning so today I started to look to see what happened. I found the end of the oil pump drive rod was broke. I was doing some reading on the problem and what people said is the shaft is made with soft metal and fail on high mile engines. I want to try to get the broken end out of the pump and put a new shaft in to see if the pump is locked before pull the pan. Anyone else have this problem.
