Bolkbich
- 8
- 18
- MAHWAH, NJ
every added 2 lbs of boost lowers your egt 50 degrees
They make almost 50 more HP, but its not the turbo, its the IP mostly.So from what ive read on here, switching to a C will pretty much net the same power? I was under the impression the 5T trucks had a bigger/diff turbo than the deuce multifuels and made 20-30 more hp?
I've never heard that. My experience has been just the opposite. The more you compress air the hotter it gets.every added 2 lbs of boost lowers your egt 50 degrees
Just so you know, if your putting a waste-gate turbo on a deuce, things are gonna be TIGHT! The IP you want is the one that says LDS on it. Most of those are governed to 2900rpm. Let me see if I can find a number for ya.Gimpy, Ive found a wastegated turbo. Do you know what IP I need or maybe a part number?
Sir,Turbos don't make power, fuel does.
