hokie8358
- 0
- 6
- backwoods ,virginia
No 1 ton pickups, K-5 blazers, and suburbans were passenger side drop until 1991. then body styles changed and transfers cases in these became drivers side drop.
I've got the cable speedo style.if i swap out the gear drive and remove the tone ring from the shaft and plac e a ring gear on it, does it have to be from same model t case or for instance a used 208 from a 700r4 or an older 241? i have sum stuff laying around
