Need some help
Alpha
Chattanooga, TN
Thank in advance for any help you can provide.
Yesterday my m1009 started struggling. It will drive just fine in first gear, but second it acts as if the acclerator is stuck and the truck is barely accelerating. In fact it accelerates better if I do not floor it. Third is the same.
Going up /down hill it will almost stall.
I dropped the tranny pan last night and refilled it.
Only thing I did recently that I don't usually do is put in almost a full thank of fuel.
In the last year I replaced the modulator for it not wanting to shift.
combatmech
Carrollton, Texas
Adding 2 stroke oil to diesel fuel will help lubricate the IP.... LS Diesel doenst have the best lubricating properties. There are other additives, tons of folks here on SS swear by 2 cycle oil. In addtion, 2 cycle oil is the least expensive route to other additives.
Anubis8472
Redford, Michigan
Best to use a TC-W3 rated ashless 2-cycle.
I use super tech outboard 2-cycle from wally world.
I dump a 16oz bottle in every tank and the engine just loves the stuff.
I also use an Opti-lube fuel treatment in the winter (for cetane and anti-gel).
I've tried several fuel treatments, but none of them come close to the 2-cycle in terms of a purring 6.2
