sewerzuk
- 9
- 18
- Seaside, OR
I have had this MEP-004a sitting in my shop now for about 6 months; it was the last of a large batch I bought at Ft. Lewis. I used it as a test bed for single phase re wiring and other modifications.
Now that I'm mostly done with the mods, I decided to move it out of my shop. However...it was missing both "doghouses." These aren't necessary for generator operation, but they do silence airflow and engine noise, and, more importantly to me, keep water out of the control panel and exhaust system. Because I live in the NW, water can be a big issue...so I decided to make some new ones!
I've never liked having to open and close the lids on the OE doghouses, so I decided to make mine solid and install vents on the sides. I was initially going to make them out of steel, but I have had this sheet of 1/8" aluminium sitting up against my shop wall for years so I decided to use that instead! The obvious benefit to the aluminum is that I didn't have to paint them to prevent rust/corrosion. But, it looks pretty good, too.
I do have access to a large brake, but I didn't have enough aluminum to do the entire project in one piece. In fact, I had to scrounge up some diamond tread "lids" to finish it off. So, each piece is cut and TIG welded together. Almost 38 feet of TIG welds! I'm not a pro welder...but I do have a fair amount of time logged with the ole welding helmet on. It has been about a year since I TIGed any aluminum together, but it only took a few inches to get back into the rhythm.
For the exhaust, I just extended it about 20" and bolted a 2-1/2" rain cap on top.
For the vents, I found these neat aluminum vents that I just flush mounted into the sides of the enclosure. I figured that one on each side (4 total) would allow for adequate airflow...but I'll put it under heavy load for a few hours and check engine and cabinet temps just to make sure. If things get too warm, I have room to mount a total of 8 more (4 intake and 4 exhaust).
Even though these panels are not sound-insulated, I don't notice any difference in sound levels when compared to a factory ASK. And, now I can put an auto-start setup on this gen without figuring out how to bolt some actuators on the lids...
