Non-green GL stuff?
Isaac-1
50
SW, Louisiana
I was just wondering how many people here buy non-green (OD, not tree hugging) stuff from GL? For me it seems to be a mix which include all sorts of non-green items, such as commercial equipment (industrial generators, fork lifts, floor jacks), as well as office stuff like color laser printers, and most recently an exercise treadmill (not picked up yet)
Ike
p.s. picked up the treadmill today, works good, missing one $20 plastic cover, not bad for 5% of original price.
maddawg308
746
Front Royal, VA
It's been years since I did on non-green items on GL. Some furniture, computers (lots of them), misc things here and there. Hope to get back into surplus equipment in the future, working up to it....
USAFSS-ColdWarrior
Chaplain
5,773
There was that pallet of expired "rubbers". What a deal!! rofl
They say that "timing is everything". With all the discussion in the national media lately about contraception, the value of your surplus may have just doubled or tripled.
(Note: NOT a political comment. Stated for "economics" perspective ONLY.)
I'm almost afraid to ask what you would use those for.:roll:
If we have to 'splain it to you, you've missed too many of your "behind the barn" classes.
wdbtchr
St. Louis, MO
I weren't askin' what they were for new, just what they was good for now.:roll:
As far as behind the barn, what did you hear? I had a bad experience back there once, my girlfirend's mother caught us messin' around. Know what she said, "MOOooo!":lol:
Mainsail
1,624
Puget Sound, WA
For a long time I have wanted to build a tool for bleeding brake lines by myself. I figured if I could find some sort of suction apparatus I could do just that. One day while perusing the GL stuff locally, I noticed that there were six gastrointestinal suction devices coming up. I threw down a $60 bid, and since nobody else wanted them, I got them for the minimum bid which was then $50.
After the EUC cleared I drove over to Ft Lewis to pick them up. They were all brand new still in their original cartons. I got them back to my little rental house in Tacoma and hauled them into the dining room, which had become a sort of garage/basement since I seldom dined formally. I unboxed one of them and assembled it. With eager anticipation I plugged it into the wall socket and flipped the power switch on, taking a step back so as not to be startled by the deafening angry sucking sounds I was expecting to hear.
Well, there was no sucking sound, angry or otherwise, just a slow lazy wheeze that sounded like someone with emphysema. I took it apart to see how it worked, and if I could make it work a little harder. Inside there was an aluminum cylinder which contained a heating element. The element would heat the air, causing it to expand, and forcing the air out through a check-valve. The element would cycle off, causing the air within to cool, and create a slight suction, which would pull air in through another check-valve through a large glass jar. It was then I realized that this piece of equipment was supposed to sit bedside, and was supposed to suck excess fluid out of body cavities after surgery, and would probably never be able to pull fluid through a brake line or out of a transmission. And I had six of them.
I found a buyer, but since medical equipment needs to be certified, and these would need to be recertified, and considering the legal mumbo jumbo in the EUC, it wasn’t financially feasible after shipping to bother, so I gutted them for useful parts and threw out the rest. Lesson learned.
Epilog: Several years later I bought a real vacuum pump from the state auction for $50, which was reported to be seized, so nobody else bid on it. I brought it home and tried to take it apart, but couldn’t figure out how to separate the pump from the motor without causing damage. I put it back together and plugged it in, and it was sucking like it was supposed to. I connected the pump to one of the glass jars and stuck a hose down the fill tube on my transmission and it pulled all the oil out of the pan. In the end, I found a use for most of the parts, especially the super cool glass jars that allow you to suck fluid without sucking it through the pump (and ruining it); they even have a built-in automatic shut-off feature.
EDIT to add: In the pictures you can see the glass jar and the wheeled base from the gut sucker. I wish I had kept more of the bases instead of just the wheels. They make great furniture movers; I'm using the one in the pictures as the base for my Honda Generator.
