gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 755
- Cincy Ohio
? Where?
Or are you talking about the belt driven ones?
The 5ton pumps are all over, you would just need to get the gear and mounting plate from a dealer.
? Where?
Yep, me too - subscribed.Subscribed (even though I don't yet have anything to put it on!).
That's correct and I was going to say exactly that, in response to Tom's post #18..........i would assume that there would need to be factors in some sort of equation, such as tire foot print area, surface turned on, and total front end weight to find the weight in psi against the friction of the ground.
No specs found, so far... but better than that, we already have positive feedback from others who went the same route....... also is there specs of different boxes i cannot seem to find, like the ross steering box, in available throw and duty cycle given a pumps line pressure and application.
Why that's almost a whole hundy LESS than an Air-O-Matic kit from Inter Agency Motor Pool.ok, the week is almost over and this is what i have found. i could fabricate and sell a kit for hyd power steering for near $1700. i could also just sell the hard to find parts, what ever they are! what does the air assist cost now? the real question is how many would really do it, not just want to.
tom
I seen a hydro system in a MV magazine that some one installed on a m60 it used a rotory valve or something around the middle of the steering shaft right beside the fuel filters.
