ilovemyblazer
- 0
- 0
- Manitowoc, Wisconsin
Hey guys, I got my first CUCV running the other day, its only got 32,940 miles.
Before I started it I changed the fuel filter, changed the oil, added plenty of fresh diesel (the tank was empty when I got it) with a little diesel 911, checked and topped off coolant.
After a little messing around I got it running, and **** does this sound like a strong motor! You hit that pedal and she jumps right up and screams! (in a good way )
MY PROBLEM: Like I said it runs great when you hit the pedal, but it doesn't like to idle. If you come off the pedal really slow I can get it to idle for about 5-10 min but then it will stall. If you come off the pedal to fast she'll die right away. I've had it running for a total of at least 30 min so I know by now its sucking up the new fuel. Also my Water In Fuel light never goes out.
Also there is a screw that is right in front of the air filter and it sticks up at a 45 degree angle, I turned once then turned it right back to its original position and that seemed to make it worse.
Any help would be greatly appreciated! Thanks alot!
