goodguyzy
- 13
- 38
- medford oregon
Maybe you don't understand, it doesn't matter if you change the fronts to the rear or whatever. Unless you put brand new tires on its going to shake. The minimum you need to do is dismount the tires and replace the valve stems. Understand when they remand these trucks some things they did right but many things they didn't. The tires are probably one of the worst choices they made.
