- 3,146
- 1,683
- Pemberton, N.J.
Any frame mounted hitch will have to be slightly trimmed to fit around the pintle and tie down brackets. Not a big deal, just something to be aware of.You can have Uhaul install your hitch or you can buy a class 3 like I did that mounts to the existing frame holes and bolt it on yourself. pretty much a no brainer. U haul car trailers have surge brakes so you do not need an electrical brake controller (I just rented one from them) and they do have an inline 4pin connector that will plug directly into the 09 harness where your 12 pin military plugs in Quick connect p/n 118312. If this link works and you need it all I spec'd it out for you.
U-Haul Moving & Storage of Westside Jacksonville: Trailer hitches
If you click on the link you will need to reselect the hd hitch
and the quick connect harness for a more accurate quote as it somehow reset when I copied and pasted.
Rick
