bcowanwheels
- 2
- 18
- KINGSPORT, TN.
Front spring over axle Modification
I,am about to start on another (stock) d60 M715 front axle referb and I need to do the spring over axle modification. I know the tie rod and drag link needs to be moved to top of hi-steer arms which my machineist is doing now but i have a question for the fellas who have (first hand experience ONLY) that have done this to stock m715 ft. axles as to what they have set there pinion angle to ? do you keep iy same as when its mounted spring under ? seems to me it needs to be increased slightly to go along with the different mounting position. i,am going to measure a chevy cucv d60 and see what that is also as its soa mounted. all help is appreciated.
bob
bob
