M3 Halftrack Restoration
Dirt71
736
Jacksonville, Florida
It was time to take a look at the front end. Man talk about neglect, the pic's speak for themselve's. Had to disassemble the whole axle to clean it up properly. I will be replacing inner axle seal's, pinion seal, hub seal's as well as brake shoe's and wheel cylinder's.
battlecr
49
Eugene, Oregon
David, thanks for taking some great photo's. I'm going to be heading into my front end pretty soon, I'll use these as a resource. I just finished rebuilding my e-brake handle. It was frozen up. It's those little items that slow you down.:roll:
Don G.
maddawg308
747
Front Royal, VA
Wow, those hubs haven't had a serious deal of maintenance since the Eisenhower Administration. Looks great so far, Dirt!
Keep up the good work!
BTW, when this half-track is done, you plan on getting back into 10-tons?
Dirt71
736
I gotta say, I do miss my 10 ton stuff, but I'll be sticking with the halftrack. It's got a certain coolness all it's own. 8)
battlecr
49
Eugene, Oregon
I hear you about the 10ton's I was assistant driver and dozer operator, I liked driving the 10ton. But you also have it right the half track has a coolness all it's own. Spent time today with the little stuff. Keep driving on.
G.
Don
maddawg308
747
Front Royal, VA
That topic has been covered in exactly 14,273 threads on SS. The front roller was added to help the half-track get itself out of ditches, if the vehicle "nosed-in", it could "roll out".
Dirt71
736
Got the front axle back together today, not alot of time to clean and paint everything as I would like to. I will be relocating my shop by the end of the month, lot's to do between now and then. As I said before, I'm more worried about everything working mechanically as it should.:D
1 Patriot-of-many
79
Zimmerman MN
"That topic has been covered in exactly 14,273 threads on SS. The front roller was added to help the half-track get itself out of ditches, if the vehicle "nosed-in", it could "roll out". "
I'm sure everything has been covered at one point on these forums, so why not just close the forums to all new posts and just have a search feature. Geez.
Wayofftrack
Sorrento, Florida
I get asked the roller question more than any other. Sometimes if I'm feeling a little freaky I tell em its a gigantic dough roller. I believe in the manual it is called an 'unditching device' It also makes a comfy seat believe it or not just don't ride up there when I'm driving.
It's all good. :beer:
