- 5,351
- 3,322
- Lexington, South Carolina
Only place I've seen the crossover cables is in MKT's that had the MWO applied. I snagged a bunch of 4 outlet cables a couple of years ago, getting down into the short rows on them. Had to scramble to find two for the last 'order'. Two outlet cables for the oven side are also hard to find - I have a spare, but I'm keeping it as a spare.
The GFI outlet/plug has a wire that goes inside and down to the inverter where it will plug into. The platform is there mainly to keep the inverter off the floor (think water) and to be able to get to the power switch and outlet plugs (inverter should always be switched off when the burners are not being used.).
